Proper engine height on 18'??
Discussion in 'Engine Questions' started by Steve Marcus, Apr 21, 2015.
  1. Steve Marcus
    Steve Marcus New Hydrodyner
    1972 18'
    Blue Spring Lake Ski Club
    Hey gang, I just spent a year and $25+k on restoring a 1972 18' Dyne and I'm ready to hang the motor on a new transom. Any suggestions on height? I'm hanging a 2001 Yamaha 200 VMax. The Yamaha book says "Mount the outboard so the anti-cavitation plate is about 5 in. above the bottom of the boat." That, to me, makes no logical sense. I think it should be even with the bottom of the boat. If it was 5" higher, it was cavitate. No? thanks for your input.
  2. tj309
    Assuming you have a 20" transom like my 72 mount it with the cavitation plate even with the bottom. How about some pics?
  3. dynebob1
    dynebob1 Boat of the Month
    Glen Ellyn, Illinois
    Please post pictures of your finished project.
    I would love to see them. Spending over 25K this thing should be sweet......
    Bob
  4. Steve Marcus
    1972 18'
    I believe the transom is 21"
    i will share a whole progression of photos when i have a chance but here's some pics with fiberglass done and prior to interior...
  5. Steve Marcus
    1972 18'
  6. jim
    21 should be even, it is on mine. Given that the water rises after it comes out from under the boat, a little higher might work If your 21 works out that way.
    Watch what happens to the cav plate as you trim in. I would also use a wedge for more in trim.
  7. jim
    That boat needs to sit on bunks IMO.
  8. tj309
    Yes bunks are much better than rollers. Rollers are hook manufacturers.
  9. nickbr
    nickbr Hydrodyner
    Australia
    none
    Wow, what a beautiful job, Steve!!!!!
  10. jim
    I just reread your original post. It says 5 inches. When I first read it I thought it said .5 inch
    The 5 inch number refers to high performance boats which run a surface piercing prop. My high performance boat ran the PROP SHAFT CENTERLINE at 3/4 inch ABOVE THE BOTTOM.
    It would cavitate on takeoff until it hooked up. The prop was designed to run that high. It would be totally unsatisfactory on a ski boat.
