RiverRat My shiny new 1971 Dyne
Discussion in 'Hydrodyne 18' started by RiverRat, May 2, 2007.
  1. RiverRat
    Shoreview, MN
    1971 Baby Dyne
    Twin Cities River Rats
    Re: My shiny new 1971 Dyne
    I finally gave in and decided to start reading that at work. I just got to the good page. I believe it's the one you linked to, but the link doesn't work. Why does work always get in the way of the things I WANT to do?
    Link works now. Same page that I'm reading now.
    The cup does cause turbulence. You will be amazed at the difference.
    I messed up the link and had to edit several times.
  4. RiverRat
    Shoreview, MN
    1971 Baby Dyne
    You are correct. The Merc page does do a decent job of explaining props. According to them, the bow lift comes from larger rake angles, not necesarilly cup. But if the cup is on the outer portion of the trailing edge or out at the tip, then the cup will increase the rake, and accordingly increase the bow lift. So it makes sense that cupping only on the inner part of the trailing edge would help decrease rake, and then decrease bow lift. Why can't they just make a water ski prop that's already set up right so I don't have to try to figure out one more giant set of details!!!
    The number of customers for ski props that would know the difference is so small that it would not warrant designing and marketing the prop. Plus, now you will get it just right.
  6. RiverRat
    Shoreview, MN
    1971 Baby Dyne
    Is it possible to adjust the trim sensor? My I-command gauges show that I am at 65% trim when it is all the way down. I would guess it's adjustable, but haven't looked into it yet.
  7. HeavyT007
    HeavyT007 Hydrodyner
    1972 Hydrodyne Tournament Skier, Merc 160 I/O
    Any suggestions for place to re gel coat my Dyne in MN?
  8. RiverRat
    Shoreview, MN
    1971 Baby Dyne
    I have heard good things about White Bear Boat Works, in, of course, White Bear Lake, MN. They are technically a sailboat shop, but it might be worth checking in with them.
