new deck boat owner
Discussion in 'Hydrodyne Flat Tops' started by buccaneerdave, Aug 11, 2008.
  1. jim
    I have not done it personally. It is a lot of work.
    Please do not junk the boat. Someone will be willing to take it on.
    There is a lot of info in the restoration section.
  2. kevinb
    GVW:
    Jim's right. Take a look at the restoration section of the Site and make contact with those that have gone through the re-core process. If you have the time and a little $$, the re-core will bring back the needed structural elements of the hull. For the best results, you will need to remove the top deck to gain full access to the project.
    I have not performed a re-core but have replaced the floor and it was not too bad of a task. I used a dremmel with a tile bit to cut through the fiberglass seams that held the floor to the hull and had excellent control.
    Another tip from Jim earlier in this string is one I incorporated with the floor replacement by using a 50/50 acetone and poly resin mix to seal the marine ply floor ( or end-grain balsa in your case) before glassing into place. I have attached a pic of a flat-top with the core being placed "back in the day; hope this helps.
    Good luck and Happy Holidays!
  3. GVW
    GVW New Hydrodyner
    70 20' Flattop
    Thanks Kevin!
  4. kevinb
    Hey GVW:
    I left out a rather important point, when working with polyester resin, make sure your work space is well ventilated and if you have access to one with the right cartridges , definately wear a respirator. There are a lot of nasty fumes associated with polyester resin (haven't worked with epoxy and may be a better option for health related fumes but more $$).
    I did some work with poly resin on a snow mobile back in high school (late 70's in the fall) with the gaage closed and got one hell of a chemical hang over; missed school for a couple days. When I replaced the floor of my 75, it was in the early summer with the garage doors open, fans running and a respirator from work (I'm in the environmental cleanup industry and we have access to them as personal protective equipment).
    Good luck and provide us with progress updates and questions.
  5. GVW
    GVW New Hydrodyner
    70 20' Flattop
    Thanks for the info Kevin!
  6. GVW
    GVW New Hydrodyner
    70 20' Flattop
    Hello Jim. It’s been awhile. I sold that mushy bottom flattop from 2010 and found another good one. I/o this time. Looking for some info on a v-4 ford. Do you or anyone else know anything about them?
    Thanks
    GVW
