Please help - wiring new fuel tank/sending unit...foolproof?
Discussion in 'Restoration Projects & Questions' started by ScottW, Jun 7, 2014.
  1. ScottW
    ScottW Hydrodyner
    1976 18' w/200Johnson and 1983 20' w/235 Johnson
    Guys,
    I recently replaced the bow mounted tank in my '76 18 OB with a new Moeller unit of the same dimensions as the original. This boat was originally rigged so you must turn on the running lights to activate the fuel gauge(?)...whatever.... I plugged in the Moeller sender like the old one (sender pre-installed in the new tank), but with the tank is 1/3 full for testing the fuel gauge "pegs E" when I turn on the lights.
    The original gauge has 4 posts like the other fuel gauge wiring diagrams I have seen online: input from sender, ground, hot, and a light. There does not seem to be much to go wrong with this system - other than user error. Would my 1976 gauge NOT be compatible with a 2013 sender for some reason? I thought I should post here before buying a new gauge....
    Thanks!
    Scott
    [vicariously boating every weekend through this great website - keep the posts coming]
    Yes, not compatible. Make sure the new one is compatible with your sender.
    The gauge and sender should get power from the ignition switch, not the light switch.
  3. tj309
    I think the standard sending unit is 33-240 ohms which is what is in the Moeller. Jim is correct in that you need a new gauge - luckily they are not expensive.
  4. ScottW
    ScottW Hydrodyner
    Thank you! That saves me from hours of troubleshooting.
    Scott
  5. tj309
    New tank with modern sending unit = need for new gauge.
    Do not wire the gauge thru the light switch. There is a purple wire (if you have a Merc) that comes out of the shift/throttle box that is 12 VDC and is ignition key controlled. Use that wire for all gauges and accessories. If you have something that draws alot of electricity such as a trolling motor or stereo use a separate lead to the battery. You should not have to turn on the lights to use the fuel gauge or any thing else. It sounds like a backyard electrician found some power and fed it to the fuel gauge.
