Hydrodyne 18 Tournament Skier Bow Stripe Dimensions
Discussion in 'Restoration Projects & Questions' started by kevinb, Sep 1, 2013.
  1. kevinb
    There have been a few who have inquired about the referenced dimensions. I have a PDF of an email that I received back in February 2000 when I re-did my stripes and will try and upload. If the format is not accepted, I will forward to the Adiministrator for posting. Alternatively, you can PM me and I'll forward it on.
  2. MICHEL DESBIENS
    MICHEL DESBIENS Hydrodyner
    LAVAL QUEBEC, CANADA
    1985 hydrodyne 155HP
    THANK A LOT IT WORK FINE FOR ME, MORE MEASUREMENT THAN I WAS EXPECTING
    GREAT THANKS TO THE FORUM
  3. MICHEL DESBIENS
    KEVIN
    READING THE PDF IT SEEMS THAN THE WIDTH SIZE IS NOT THE SAME FORM RIGHT TO LEFT
    FROM RIGHT I HAVE 6 INCHES TO THE LEFT 11 INCHES FOR THE FIRST STRIPE
    AM I READING WELL
    FOR THE SECOND ONE IT START FRROM 6 INCHES TO 9 INCHES.......
  4. kevinb
    The my stripes are 6 inches wide (the email indicates 6.125), and approx. the same distance appart. The other measurements (1,2,3, and 4...1a, 2a, 3a, and 4a) are from the bow to the port (passanger side) and bow starboard (drivers side), to get the diagonal layup. Measurements 8 and 9 are the diagonal length of the stripe accross the bow, need to give an additional 10 to 12 inches for the lap down the side. If you make the marks up the sides in pencil and layout the stripes in 3M blue masking tape it should check in to spec., before having the decal material cut
    Hope this makes sense,
    Kevin
  5. MICHEL DESBIENS
    Understood all this but the width size are not the same from driver to left ( as per measurement)
    It goes from 6 to 11 for the firs layer and from 6 to 9 from the second layer. Then the width size increase WRONG ASSUMPTION VISUAL EFFECT ONLY
    Left Right
    1 42.50 -1a 14
    2 53.50 11 -2a 20 6
    3 63.50 -3a 26
    4 72.50 9 -4a 32 6
    Will do marking with the specs as you suggested
  6. kevinb
    Hi Michel:
    IMHO your over thinking this. If you have a decal shop cut you the material at 6 inches with about a foot extra in length for each stripe, make the reference marks up each side of your boat with a pencil, lay the decal material (with the backing in place) on the marks, and check the distance between the stripes (should be ~6 inches), adjust your pencil marks as needed so 6 inches is achieved between the stripes, apply and enjoy. The transfer of the decals to the hull is another chapter/discussion, but not as complicated as the side decals.
    Take care,
    Kevin
  7. MICHEL DESBIENS
    HI KEVIN
    I made the measurement on the boat with a chalk rope and the stripes are fully 6 inches from right to left
    My understanding from pictures was completely wrong with a false visual effect from the pdf pictures.
    So the measurement are completely right.......:)
    I ordered the blue and red stripes accordingly.
    Thanks to the forum and share knowledge.
